Connection Encryption
  • Apr 29, 2014 3:42 AM UTC
  • 58 views
We are trying to connect to Microsoft Azure SQL DB in cloud thru our client FME to transfer data.
Is it possible to connect SQL Azure with Encrypt connection option from client FME as available for SQL Server and shown in the attached screenshot.
 It's critical to our deliver  can someone in FME support reply ASAP ?
Thanks & Regards
Best answer by david_r
at first sight it doesn't seem like it's supported. However, I recommend you contact Safe support (https://safecommunity.force.com/knowledgeSubmitCase) directly to get the full details.
David
  • Apr 29, 2014 4:02 PM UTC
David
