Connect and execute Microsoft SQL on Python Shutdown Script
  • June 27, 2018
  • 19 views
Has anyone successfully executed an insert\\delete SQL statement to a SQL database via Python in the Shutdown Script?
  • June 28, 2018
Have a look at using the pyodbc module, see also this discussion on StackOverflow: https://stackoverflow.com/a/33787509
The SQL Server writers also have a parameter you can set, containing a SQL command to execute at the end:
