Configure Esri Feature Class aliases in a dynamic workflow
  • Mar 18, 2020 3:08 PM UTC
  • 191 views
ruben.perez
Hello,
I am working in a workbench for exporting layer from Oracle Spatial to a FileFeoDb, taking the layers to export of a configuration excel.
I've already done it, but now I need to configure the alias of every feature class I manage in the process
I have searching for a solution but I cannot find anything. My expertise un FMW is not very high, so I need some advise on this...
I'm thinking in aggregate aliases in the same way I did with layer names, but I'm not really sure where to configure the attribute generated contained all aliases aggregated.
thanks!
@ruben.perez you can set the format attribute geodb_feature_class_alias with the feature class alias name. This will set your feature class alias name when FME creates the feature class. More on FME and Geodb aliases in this article: Working with Geodatabase Field Aliases: Altering Alias Values
ruben.perez
  • Mar 19, 2020 10:34 AM UTC
Thanks a lot!
I understand now how to do it, but I still don't know how to implement it in a dynamic scenario...
Where I have to add all that aliases? (I guess I have to aggregate them in the same way as layer names...).
Any advice would be appreciated!
thank you!
