Concatenate list values
  • Nov 29, 2013 4:42 PM UTC
  • 77 views
farfar
Forum|alt.badge.img+12
Hi all,
Generalty i use ListConcatenator to concatenate ALL list items. I need to concatenate list  items without the first item. Is there a specific transformer that can i use?
Thanks an advance.
FarFar
Best answer by takashi
I would apply Itay's 1st approach with a StringReplacer after concatenating.
Assume the separate character is a comma, the StringReplacer parameter settings are:
Attributes: _concatenated
Text to Find: ^[^,]*(,(.+))?$
ReplacementText: \\2
Use Regular Expressions: yes
If all elements of the list are not empty, there is the 3rd approach. That is, make the first element empty, then concatenate non-empty elements. AttributeCreator: _list{0} <-- <empty> ListConcatenator: Drop Empty Parts = Yes
Appendix:
A concise Python / Tcl script can concatenate list without the first element. PythonCaller
import fmeobjects def concatenateListWithout1stElement(feature):     delim = ','     src = feature.getAttribute('_list{}')     feature.setAttribute('_concatenated', delim.join(src[1:]) if src else '') -----
TclCaller
proc concatenateListWithout1stElement {} {   set delim {,}   set elements {}   for {set i 1} {[FME_AttributeExists "_list{$i}"] == 1} {incr i} {     lappend elements [FME_GetAttribute "_list{$i}"]   }   return [join $elements $delim] }
Takashi
  • Nov 30, 2013 3:35 AM UTC
Appendix:
TclCaller
Takashi
