?Comprehensive, centralized way to store published parameter passwords used by multiple workspaces in FME Server?
  • Feb 1, 2017 9:15 PM UTC
  • 6 replies
  • 131 views
I am running multiple workspaces that have the same published parameters that are passwords. Is there centralized way to store published parameter passwords that are used by multiple workspaces?
I can't find anything in the documentation about how to do this.
erik_jan
Forum|alt.badge.img+26
  • Feb 1, 2017 9:19 PM UTC
What kind of passwords are you referring to.
If it is database connections, FME stores these in a connection file outside the FMW file.
They are references by connection name, so the username, password and database name are not stored in the FME file.
erik_jan
  • Feb 1, 2017 9:22 PM UTC
And FME 2017 has the same option for Web service connection information as for database connections.
itay
Forum|alt.badge.img+19
  • Feb 1, 2017 9:26 PM UTC
unfortunately this is not the case for published parameter even password type and they are quite easy to reveal.
There are several ways to accomplish that for example a centralized file containing passwords that is read via a startup python script.
I am sure other users have other ideas and experiences to share.
Hope this helps
  • Feb 1, 2017 11:36 PM UTC
I'm referring to passwords that are stored as published job parameters, not database connections. I was aware of the fact that FME stored database connections differently from his article: https://knowledge.safe.com/questions/22574/fmeserverjobsubmitter-logging-password-in-clear-te.html
Basically, I'm looking for a centralized way to pass published job parameter passwords to scheduled jobs on FME server......
My apologies for not being more clear in my question.
  • Feb 1, 2017 11:40 PM UTC
Hope this helps
@itay, thanks for this reply!
Yes-You've suggested a decent work around that I hadn't thought of. It would definitely be possible for me to grab passwords from centralized file via a python script. That being said, I wish there was an easier way.... lol.
  • Feb 2, 2017 8:50 AM UTC
The easier way is to use the FME Server / Desktop named connection functionality ;-)
It's also a lot more secure.
