Combine attribute tables
  • Nov 10, 2016 10:03 AM UTC
  • 82 views
Hello world of Safe!
A few transformers create objects with the following attribute tables 'Table 1' and 'Table 2'. The attribute 'ID' describes where A is B. I want to combine these tables like you see it in the picture under 'Goal'. First I thought I could merge them with the FeatureMerger, but after that the output just shows the four rows with the ids which exists in both tables.
Important: The ids in Table 1 exist in Table 2 in every case. It is not a coincidence!
Thank you for answers!
Best regards,
Felix
Best answer by ciarab
The feature merger should be okay to use but you may want to take the data coming from the different ports such as Not Merged to account for when a match was not found.
ciarab
Forum|alt.badge.img+10
  • Nov 10, 2016 10:15 AM UTC
Sometimes you lose the sight of the wood for the trees. Thank you very much!
ciarab
  • Nov 10, 2016 10:38 AM UTC
I have done it myself!
