cmd and python un FME
  • July 27, 2018
  • 15 views
Hello,
I want, after pressing the ''run'' button in FME and before starting the translation that windows cmd to open, to print some text of my choice for a time period I choose, and then close itself and next the translation to start and continue normally till the end
Is there any way to that using the startup script in the workspace parameters ?
stalknecht
Forum|alt.badge.img+19
  • July 28, 2018
You can create batch file with the following contents:
echo "This is the message you want to give"
ping 127.0.0.1 -n 6 > nul
exit
The echo command is for displaying the text
The ping command is a workaround to delay
The exit command will close the command window
then you can use this python script to start it
import os
os.system("start c:\\temp\\test.bat")
