Clip lines and add more attributes values in one cell in attribute table of lines from attributes of pies
  • Dec 13, 2019 6:46 PM UTC
  • 9 replies
  • 79 views
I want to get this. I upload shp, xls and fmw. Can you give me some idea. Thanks a lot.
  • Dec 14, 2019 9:34 AM UTC
The uploaded files are broken for some reason. Please upload them again.
  • Dec 14, 2019 9:51 AM UTC
I'm not able to upload until Monday. Then I will.
  • Dec 16, 2019 8:09 AM UTC
example.xlsxpie_maker.fmw roads_part.zip
  • Dec 16, 2019 9:33 AM UTC
Hi @maloks, I think you need to modify the workspace at these two points.
First, you have to create point geometry based on LAT and LON with a VertexCreator before reprojection, since features read from Excel dataset don't have any geometry.
Second, you cannot use coordinate system name "HTRS96" in the Reprojector setting, since FME doesn't support it. You need to select an appropriate coordinate system from the FME Coordinate System Gallery.
  • Dec 16, 2019 10:02 AM UTC
Making pie shapes is ok, I made custom coordinate system HTRS96. My problem is in the next step where I have to get id from pie in the attribute table of roads like on the picture above.
  • Dec 16, 2019 10:22 AM UTC
I cannot see the picture. Could you please post it again?
  • Dec 16, 2019 10:39 AM UTC
So, here is the picture.
  • Dec 16, 2019 11:25 AM UTC
You can use the AreaOnAreaOverlayer to overlay the pie-shape areas and populate Cell IDs of overlapped areas into a list attribute. Then, concatenate the list elements (i.e. Cell IDs) with the ListConcatenator delimited by your preferred separator and transfer it to clipped lines with the Clipper.
Hope this helps.
  • Dec 16, 2019 2:05 PM UTC
Hope this helps.
Thanks a lot.
