Change name of Feature Class in Dynamic GDB
  • Oct 11, 2017 12:18 PM UTC
  • 120 views
Hi i am converting DWG to FileGDB and using Geometry Filter, while translating "A" Layer is being divided in three parts i.e A_Point, A_line, A_Polygon similarly "B" layer to B_point, B_line etc.
I want to change the layer names in writer, I am using Dynamic Writer.
Do i need different dynamic writer for each layer or any other option?
Best answer by david_r
Create a new attribute for the output table name and set the schema defintion name as the "old" table name, e.g.
pratap
Forum|alt.badge.img+12
  • Oct 11, 2017 12:22 PM UTC
Pass the required value in some attribute (i.e. FEATURE_CLASS_NAME) attribute to the writer and select feature class or table name option based on same attribute
  • Oct 12, 2017 7:20 AM UTC
Hi @pratap
I have tried the same. But its not working in my case, Can you please share any example workbench?
it might the case i am missing something..
  • Oct 12, 2017 7:35 AM UTC
pratap
  • Oct 12, 2017 7:42 AM UTC
Hi @pratap
Kindly review the attached
safe-dheeraj.fmw
