Centerline Replacer comes up short.
  • June 19, 2021
  • 126 views
larue
Forum|alt.badge.img+12
I am trying to generate centerlines from parallel line pairs which are transformed into bounding boxes, then areas. This works but the centerlines do not extend all the way to the edge of the area/bounding box:
CreateCtrLineShort1There does not seem to be any settings in either bounding box, area builder, or centerline replacer to change this. Am I going to have to add a snapper? Any reason why it does not go to the edge?
Thanks,
@larue​
Best answer by larue
Here is a possible answer using neighbor finder and line extender, with line length set to the distance:
CreateCtrLineShort2
larue
  • June 20, 2021
CreateCtrLineShort2
danilo_fme
Forum|alt.badge.img+53
  • September 5, 2021
CreateCtrLineShort2
Nice @larue​
larue
  • September 6, 2021
I have also had some good luck with the SmartCleaner. You need to play around with the parameters, but it will extend to the edges.
