Capture and Log Python Caller Errors?
  • Jan 23, 2018 3:56 AM UTC
  • 288 views
In my workbench, all "Not Merged" / "Rejected" paths etc, redirect to a FeatureWriter that logs errors to the database.
However, the PythonCaller only has the "Output" path - how would I capture and log these exceptions?
Could I do something like this?
  • Update PythonCaller to Catch the Exception and store detail in an Attribute (don't raise exception)
try:
except:
feature.setAttribute("Error", sys.exc_info()[0])
  • Use Tester to check if Error Message exists
  • Fork based on Error contents
  • Wire-up to exception-logging path
  • Jan 23, 2018 5:14 AM UTC
If you don't want the translation to stop when an exception is raised at runtime, you have to implement the script to detect the exception and output a specific feature which contains information on the error, and then filter out the feature with a subsequent transformer e.g. Tester, TestFilter etc.
Probably you want to vote up this Idea: Add Rejected-port to the PythonCaller
  • Jan 23, 2018 5:26 AM UTC
Thanks Takashi, will do.
  • Jan 23, 2018 5:28 AM UTC
Just for the benefit of others, the above process can be followed - I've also added additional information, such as the line number:
import sys
    try:
    except Exception as e:
        error = 'Error on line ' + str(sys.exc_info()[-1].tb_lineno) + ' - ' + str(type(e).__name__) + ' - ' + str(e)
        print error
        feature.setAttribute("_error", error)
apence231
Forum|alt.badge.img+10
  • May 15, 2019 12:11 AM UTC
import sys
    try:
        print error
This worked like a charm! Thanks for the bit of code-
