Can't set DGN V8 global origin in workbench
  • March 27, 2015
  • 16 views
I'm using FME Professional 2015 and have been trying to set the global origin for the DGN V8 writer but it does not seem to work. From what I understand I should be able to set UOR X Global Origin and UOR Y Global Origin, but I've had no luck. Is there a trick to getting this to work - something I'm missing?
Best answer by pratap
I dont think, changing just the global origin of the dgn file will work. We have to coordinates of the data as well, so use offsetter transformer to shift the data as well.
Pratap
pratap
Forum|alt.badge.img+12
  • March 30, 2015
Pratap
