Can a reader be disabled programmatically?
  • Jun 5, 2017 12:51 PM UTC
  • 5 replies
  • 70 views
george
Participant
Can a reader be enabled or disabled in run-time based on certain conditions? Or a more general case: can a set of bookmarked transformers/components in a workspace be enabled or disabled in run-time based on some conditions?
Thanks in advance,
George
mygis
Forum|alt.badge.img+14
  • Jun 5, 2017 1:35 PM UTC
Hi @george
I would use a Tester transformer or any filter transformer to do so based on a certain criteria.
Cheers.
Lyes
  • Jun 5, 2017 7:46 PM UTC
@george
Example here using a Published Parameter to specify which of three Readers to use. Choose Run with Prompt to execute the Workspace. A multiple choice of three values is displayed using a Published Parameter.
This Published Parameter is used in the Workspace and split into 1, 2 or 3 features depending on the number of values chosen. These values are then processed by AttributeFilter to trigger the reading of any combination of the three FeatureReaders.
choosereaders.fmw
  • Jun 6, 2017 7:58 AM UTC
@george
choosereaders.fmw
Yes, definitely this is much preferred to using a Tester after the input feature type.
lars_de_vries
Forum|alt.badge.img+10
In addition to @gisinnovationsb and @mark_1spatial you can consider to use FeatureReaders instead of a regular reader. When you start your workspace with e.g. a creator and let it pass a filter based on a Published Parameter, you can choose which FeatureReader should be used.
mygis
  • Jun 13, 2017 12:22 AM UTC
Yes @lars_de_vries
That could be an option too. I will +1 it ;)
