Best way to use ArcPy without changing the python interpreter
Hi
Any idea of the best method for using the Arcpy library without changing the interpreter to ESRI?
Thanks
Best answer by david_r
It is theoretically possible, but the Python interpreter defined in FME Server needs to be identical to the one used by ArcGIS, if not there's a very good chance it won't work at all.
The trick is to set the PythonPath exactly like the one used by the ArcGIS Python interpreter. To find these paths, open the ArcGIS Python interpreter and type:
import sys
for x in sys.path:
    print x
This will dump all the entries in the PythonPath used by ArcGIS, and you can copy those into the non-ArcGIS Python interpreter before loading the arcpy module. Here are the values from my installation, you will have to use your own paths, of course:
import sys
sys.path=[]
sys.path.append(r'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ArcGIS\Python 2.7')
sys.path.append(r'C:\Python27\ArcGISx6410.2\DLLs')
sys.path.append(r'C:\Python27\ArcGISx6410.2\lib')
sys.path.append(r'C:\Python27\ArcGISx6410.2\lib\plat-win')
sys.path.append(r'C:\Python27\ArcGISx6410.2\lib\lib-tk')
sys.path.append(r'C:\Python27\ArcGISx6410.2')
sys.path.append(r'C:\Python27\ArcGISx6410.2\lib\site-packages')
sys.path.append(r'C:\Program Files (x86)\ArcGIS\Desktop10.2\bin64')
sys.path.append(r'C:\Program Files (x86)\ArcGIS\Desktop10.2\arcpy')
sys.path.append(r'C:\Program Files (x86)\ArcGIS\Desktop10.2\ArcToolbox\Scripts')
import arcpy
Let us know how it works for you.
David
  • March 24, 2016
Hi
Why can't you change the Python interpreter? It's pretty trivial.
David
  • March 24, 2016
I will probably have to roll out a workbench to FME Server and even though its a small change to a file config, it will be a huge change process here so its easier if i can call it externally to ESRI's interpreter as FME Server is setup to look at the default interpreter.
  • March 24, 2016
import sys
for x in sys.path:
    print x
import sys
sys.path=[]
import arcpy
David
  • March 24, 2016
cheers, thats spot on!
ngoorman
Forum|alt.badge.img+3
  • January 26, 2017
import sys
for x in sys.path:
    print x
import sys
sys.path=[]
import arcpy
David
sys.env is incorrect; it should be sys.path
  • January 26, 2017
Yes, you're absolutely right, thanks for pointing it out. Fixed.
