Batch Run a workspace failing with feature type as a parameter
  • Jul 16, 2019 12:38 PM UTC
  • 128 views
I have a workspace that uses a feature reader to read just one table from a geodatabase. I need to batch run this workspace for every feature type in the geodatabase.
I created a new workspace with a schema reader and a workspace runner to run the original workspace, with the feature type populated from the fme_feature_type_name from the schema reader. The feature reader in the child workspace fails.
If I hard code the feature type in the published parameter in the workspace runner in the parent workspace, the feature reader in the child workspace runs. But as I need to batch run this doesn't solve my problem.
I've made a pair of sample workspaces that replicate this issue with an Excel Spreadsheet. They're here:
Is there any way to do a batch run with a feature type as a parameter that can be varied to cover the whole schema?
Best answer by itay
Hi @ella_s,
You can add a ParameterFetcher transformer in the child workspace to grab the parameters values and add them to attributes and then use them in the FeatureReader.
chrisatsafe
Hi @ella_s,
If you leave the Feature Types to Read parameter blank inside the WorkspaceRunner it should read all three (Sheet1, MySheet, and AnotherSheet).
  • Jul 22, 2019 7:36 AM UTC
Hi @ella_s,
Hi @chrisatsafe, thanks for the response but that doesn't solve my problem. I've inherited a complicated child workspace that needs batch running and unfortunately it really does need to be ran one geodatabase table at a time, otherwise I wouldn't need the parent workspace at all.
itay
Forum|alt.badge.img+19
  • Jul 22, 2019 12:48 PM UTC
Hi @ella_s,
  • Jul 26, 2019 10:39 AM UTC
Hi @ella_s,
Thanks @itay that worked for me. Another workaround I've been told about is to create a new published parameter as a text field.
