Batch process gdb update
  • May 1, 2017 5:59 PM UTC
  • 66 views
I am fairly new to FME. I currently have 286 old gdb that consist of 15 feature classes, they needs to be updated to a new gdb. Some of the updates includes: changing a point to polygon, merging feature classes, changing fields name, and also mapping value for subtype. I have already figure out how to update an individual gdb.
I was wondering if it is possible to batch process, and update all of the gdb. Right now, I am playing around with batch deploy, but I can't seem to figure out where to start.
Can you please help me out? It would be very much appreciated :-)
Thanks,
Vincent
  • May 1, 2017 6:42 PM UTC
How about a WorkspaceRunner transformer to call your workspace from a controlling Workspace?
First Workspace reads the GDB folders using Directory and Filepath reader, and passes the values into the second Workspace that does the processing.
Example here: https://knowledge.safe.com/articles/1469/batch-processing-using-the-workspacerunner-1.html
Thanks Mark! I will try this out. :-)
