Batch files not completing
  • November 9, 2012
  • 12 views
I have FME batch files that will run manually, but when started by the Windows scheduler they get hung when attempting to open a geodatabase.  I suspect this is a Window scheduler problem, but I will glady accept any suggestions/thoughts.  Below is the last couple of lines of the log file.
|INFORM|Loaded module 'GEODATABASE_FILE' from file 'C:\\app\\FME\\GEODATABASE9.dll' 0|INFORM|FME API version of module 'GEODATABASE_FILE' matches current internal version (3.7 20111219) |INFORM|Opening the Geodatabase reader
Have any of you out there in FME Land experienced a similar problem?
Hi Gary,
if that's the last line it's probably a license problem.
The next line would be:
FME has checked out an Esri license. The product checked out is 'ArcInfo'
Is the windows scheduler running on a different machine, in a different network, as a different user,... ?
Kind regards
Uta
  • November 13, 2012
Hello Uta,
Thanks for your inquiry.  Correct the license was getting stopped because of a problem with administrative rights.
Thanks again.
Gary
