Batch deploy disabled
  • September 15, 2016
  • 63 views
Hi again ,
I have the attached FME project ( Image ) , that execute another FME in batch. The problem is that I haven't writer in this FME project , because I don't need it for the batch process , but without writer I can't create the .bat (Batch deploy) of the diagram , is disabled.
Any idea to put a writer that let me generate the batch deploy ???.
Thanks in advanced for your help , is great !
Solved , thanks , I have created an output like log in MDB and it is solved.
Thanks again !!
