Batch deploy
  • Sep 14, 2016 9:26 AM UTC
  • 66 views
Hi again ,
Another question please.
If I have two diferent readers , one is a GDB file , and the other is a DGN file , how can I generate the batch deploy ???
Actually only let me add one source dataset , the DGN or the GDB but not the two at the same time.
Thanks in advanced for your help !!
Best answer by itay
Hi @xavigarciamar, the wizard will let you choose one writer, but the batch will use both.
itay
Forum|alt.badge.img+19
  • Sep 14, 2016 10:50 AM UTC
Ok thanks Itay !!!! your are great , it works as you say , thanks again for your help !! Regards !!!
