Batch analysis of FileGDB layers
  • Sep 27, 2017 6:29 PM UTC
  • 78 views
I have a situation where I have two file geodatabases. They contain subsets of data from the same spatial areas and have a structured coding (see example image below).
As the layers can be large I wan't to process them in a workbench one pair at a time. But there are many pairs, so I would want to batch this. I know of a method to do this using PATH reader and WorkspaceRunner, when the inputs are Shape files. But with the PATH reader you can't map in to FileGDB layers. I do not want to convert to Shape, as I would loose the complex attribute names.
Any suggestions how I could send each pair at a time to a WorkspaceRunner in batch? Attached is the logic how it would work with Shape-files.
Thanks for any ideas!
bruceharold
Forum|alt.badge.img+20
  • Sep 27, 2017 6:44 PM UTC
How about have two GeodatabaseFile readers with * merge filter (i.e. single merged feature) and a TestFilter with an output port for each 'ends with' case and test fme_feature_type.
Thanks for the suggestion. I was thinking something similar, but it's not a sustainable solution as the approach needs to be generic. The 'ends with' part can change over time and I would need to recreate the testfilter everytime.
