Automatically update parameter with new data
  • Sep 22, 2016 7:58 AM UTC
  • 109 views
zzupljanin
Forum|alt.badge.img+5
Hey everybody,
For example, I have .fmw with a user parameter (with choce list) that contains all users. But user list can change: some of them can be deleted, and there can also be new ones. This list is fetchable, so at any time I can get it in txt file or any. But I want the whole proces to be automatic.
Question: Can I automatically update choice list in published parameter using other source?
Thank you for your help
Best answer by david_r
That is unfortunately not easily done, at least not automatically.
You can manually import the users from your data source, however, it is pretty easy:
  • Sep 22, 2016 9:07 AM UTC
zzupljanin
  • Sep 22, 2016 11:05 AM UTC
Yeah, that's what I tought. Thank you, sir
ryanw
  • Apr 1, 2019 7:46 PM UTC
Has anyone solved this? I have the exact same problem (automatically update choice list in published parameter using another source). One method I could think of offhand is having a second workspace that inserts appropriate text into the .fmw file based on the other source (list of user names, for example, from a database).
