Automatically detecting change of a attribute revision
  • Nov 12, 2019 10:25 PM UTC
  • 54 views
Hi guys,
I have created an FME workbench that runs an output. This I have then automated by adding it into a batch file and run via a scheduler. I have an issue where a certain attribute I have to manually change in the attribute manager due to its revision.
I was thinking of using the counter and also read this article https://knowledge.safe.com/articles/33899/change-detection-2.html but not sure how exactly the workbench wil detect the change of the new revision. The other option maybe having a popup box similar to counter that suggests you need to add the revision but unsure if this can be picked up in the .bat or via another method.
Example - Currently it is, for example, it is: DG01 and then next weeks run it will be DG02 but that will have to be manually changed.
Forum|alt.badge.img+54
  • Nov 13, 2019 7:54 AM UTC
If it's a weekly thing and you want to increment by 1 each week, you could evaluate the current date against the starting date and calculate the number of weeks to get your revision number.
