AttributeFilter doesn't show format attributes
  • Jan 30, 2015 1:36 PM UTC
  • 5 replies
  • 64 views
Dear FME community,
with the AttributeFilter I can successfully route features to different output ports, depending on the value of an attribute. Is there a way to add output ports for the format attribute fme_basename as well?
I have some Excel files read from a directory, but if I activate the sign on "Show format attributes", it doesn't show any format attributes. Is there a trick on how to add the filename of the Excel files as an transformer port?
Kind regards
Thomas
gio
Forum|alt.badge.img+15
  • Jan 30, 2015 1:57 PM UTC
At the select source dataset you must first select
Format: Microsoft Excel and
Dataset: the directory where your excellfiles reside.
When u klick next..it will read all excel datasets and you can import the names as choicelist.
If u enter a excelfile full path, it will only see that one  and you get no choices.
gio
  • Jan 30, 2015 1:58 PM UTC
you must use advanced browser to pick directory (directories)
gio
  • Jan 30, 2015 2:01 PM UTC
and btw, this thing is a attribute filter....so it wont filter files.
If you add a directory and choose some sheets, it will read in all their attributes.
  • Jan 30, 2015 2:19 PM UTC
Hi Gio,
I think I did it excactly as you wrote with the advanced browser. However, the only attributes that are shown are the user attributes, not the format attributes. It does show all the tables available of the feature, as in the image. So far so good. But the next step is to show me the format attributes, which should be in the image above.
gio
  • Jan 31, 2015 5:59 PM UTC
Hi, yes, pressing format attributes does nothing...
Maybe a bug?
