[Attribute Handling] Summarize rows
  • Nov 14, 2016 2:23 PM UTC
  • 186 views
Hello World of Safe,
as you see in the picture I uploaded, I want to summarize all the rows with the same value in the column "paaranzahl". Is that possible?
Best regards, Felix
Best answer by david_r
You can use an Aggregator with "paaranzahl" as group by, mode set to "Attributes only", accumulation mode "Merge incoming attributes" and list all your attribute "Klasse n)" in "Attributes to sum".
  • Nov 14, 2016 2:37 PM UTC
Great, works fine! Thank you :)
