associate rows with previous rows
  • Mar 5, 2020 3:40 PM UTC
  • 6 replies
  • 92 views
Hi
i have a data set that looks like this
Row_IDNameType1Ashville Medical PracticeGP Practice2Dr CampbellStaff3Dr PringleStaff4Dr AiswortStaff5Brierly Medical CentreGP Practice6Dr A J LittlewoodStaff7Chapelfield Medical CentreGP Practice8Maxine OrrStaff
9Dr BannonStaff
what i would like to do is create a new attribute for each feature that contains the name of the GP Practice the Staff belong to.
Which would look like this:
Row_IDNameTypeName of GP Practice1Ashville Medical PracticeGP Practice
2Dr CampbellStaffAshville Medical Practice
3Dr PringleStaffAshville Medical Practice
4Dr AiswortStaffAshville Medical Practice
GP Practice
6Dr A J LittlewoodStaffBrierly Medical Centre
GP Practice
8Maxine OrrStaffChapelfield Medical Centre
9Dr BannonStaffChapelfield Medical Centre
but, as you can see, there is not a fixed number of staff per GP Practice.
Any help greatly appreciated
Thanks
Mark
erik_jan
Forum|alt.badge.img+26
  • Mar 5, 2020 3:45 PM UTC
Have a look at the settings for the AttributeCreator transformer.
At the top you will find an option to get attributes fro the previous or next feature.
That should help you creating the attribute you need.
  • Mar 5, 2020 3:55 PM UTC
Hi Erik_Jan
thanks for the speedy response. I have been trying to make the Previous \\ Next feautures to work in my scenario, but can't work out a way to make that dynamic.
As there can be anything from 1 to 7 staff in a GP Practice, so sometimes i need 1 prior feature, sometimes 2, ... and sometimes 7.
Forum|alt.badge.img+54
  • Mar 5, 2020 4:01 PM UTC
Hi Erik_Jan
Because the features are processed in order, you should only need to access the previous feature, once you have set the value for row2 you can use that in row 3 etc.
Gives this output
dustin
Forum|alt.badge.img+36
  • Mar 5, 2020 4:08 PM UTC
You can use the method outlined by @erik_jan, along with the conditional values in the Attribute Value parameter.
Set the number of prior features to the max number of staff below the practices. You can choose as high of a number as you wish.
In the Attribute Value column, use the conditional value option to build the following test...one for each of the number you specify. The next would be feature[-2].type, with the Attribute Value set to feature[-2].name, etc...
You will want these in sequential order in the conditional values. The [-1] test should be on first.
  • Mar 5, 2020 4:48 PM UTC
Gives this output
thanks everyone, its doing exactly what i needed.
