Assessment FME
  • April 16, 2018
  • 31 views
I am looking for a solution that results in the simplified envelop of a 3D-object. The purpose it to indicate the reservation area of a 3D-object, without revealing the details of that 3D-object. This is a typical demand that Safe Software will encounter in the future when speaking to people handling BIM (Building Information Model) workflows.
Here some examples:
The purpose is to do that on minimally following 3D-objects (input)
The expected result (output) would be something like this (see red lines):
We need at least a box, ideally a more detailed geometry (e.g. a trapezoidal geometry)
It’s mandatory to take into account the orientation of the 3D-objet in the 3 X,Y,Z axis and minimize the resulting geometry volume. As an example following result would be useless:
Can transformers be the solution to my requirement? The most likely transformers I have found are
BoundingBoxReplacer : but it should also handle 3D coordinates , and ideally not generate the bounding box, but rather a simplified envelop
CSGEvaluator: but I cannot estimate what the result would be using this transformer
Is there any transformer that does what we are looking for? That would be awesome.
If not. Would it be possible to add it on the requirement list and inform me when it’s available?
If FME can handle this kind of requirement , we will probably buy a license of FME.
Best regards.
Vincent DE BREUCK
Lead Methods Officer
DESIGN - LINES AND TRACK
T +32 2 432 73 32
M +32 476 28 83 41
Fonsnylaan 39 Avenue Fonsny
1060 Brussel/Bruxelles - Belgium
www.tucrail.beDisclaimer
lars_de_vries
Forum|alt.badge.img+10
You could use a BoundsExtractor, BoundingBoxReplacer and an Offsetter to create your 3D box. If you would like to have a better description of the 2D shape, you could also consider a HullReplacer in stead of a BoundingBoxReplacer
  • April 16, 2018
Hi Lars,
Thanks for your answer. Do you mean we should use all 3 transformers? (BoundsExtractor, BoundingBoxReplacer and an Offsetter). Or just 1 of these 3 transformers to have each time a similar result.
Vincent
lars_de_vries
Hi Vincent,
I mean you should use them all three in that order.
Actually I made a small mistake. You'd better use the 3DForcer in stead of the Offsetter, since it replaces the Z-value and use the Extruder to create the volume.
I hope this works for you.
lars_de_vries
Hi Lars,
Vincent
Hi Vincent,
