Any suggestions on how to convert contents of attribute into bullet list in Markdown?
  • Oct 25, 2018 5:45 AM UTC
  • 36 views
friesewoudloper
Participant
My dataset has an attribute that contains a list of item descriptions and hyperlinks:
Item 1|http://www.item1.com^Item 2|http://www.item2.com^Item 3|http://www.item3.com
I'd like to change the contents of the attribute into a bullet list in Markdown:
* [Item 1](http://www.item1.com)
* [Item 2](http://www.item2.com)
* [Item 3](http://www.item3.com)
What would be the best way to do this? The list in the attribute can contain zero, one or n items.
  • Oct 25, 2018 7:11 AM UTC
On solution could be to use an AttributeSplitter on "^" followed by a ListExploder and a StringReplacer where you look for the following regex:
and replace it with:
* [\1](\2)
friesewoudloper
Participant
* [\1](\2)
Thank you very much!
