Analyze attribute values for whole words
  • Apr 21, 2018 6:29 PM UTC
  • 87 views
Forum|alt.badge.img+4
Anyone know of a good way to analyze attribute values, and determine if a given value is a word in English?
Or maybe even check it against a custom dictionary of names? I'm trying to clean up a bunch of values that have spaces from when the PDFs were output to data via OCR, so it looks like this:
Attribute ValueWhat I want attribute to be corrected toThi s is a sent e nc e.This is a sentence.
pratap
Forum|alt.badge.img+12
  • Apr 21, 2018 6:45 PM UTC
I'm not sure 100% but I will suggest you to use attribute splitter and divide with the help of " " (space). If the list has signal letter other than "a" then merge left list{x} and right list{x} such that word will form.
Above example will be like
Thi s is a sent e nc e --> Thisis a sentence
based on the results you add further more
Pratap
pratap
  • Apr 21, 2018 6:49 PM UTC
  • Apr 23, 2018 6:24 AM UTC
That's a pretty cool, but potentially difficult issue to deal with.
How do you plan on dealing with ambiguities, e.g. "a void" vs "avoid"?
pratap
  • Apr 23, 2018 6:35 AM UTC
Good question @david_r
At the end, english is a language and depends on the situation the meaning of the sentence will change. In this context, we are joining word/words and trying to make a sentence so the words "a void" or "avoid" both are correct in english :)
So it depends on @dmatranga to decide...
Pratap
