aggregate values in key-value pairs and write matrix
vki
Forum|alt.badge.img+7
This is my initial data:
Name,Value
sza034,ber_afu
sza033,ber_awn
sza034,ber_afl
sza033,ber_afu
sza034,ber_afu
sza032,ber_awn
sza034,ber_afl
sza033,ber_fff
sza033,ber_bgt
sza033,ber_afu
sza033,ber_jij
The result has to be a matrix, with a row for each unique name and a column for each unique value.
the fields in the matrix have to be filled with "yes" or "no":
Name,gschber_afl,gschber_afu,gschber_awn,gschber_fff,gschber_bgt,gschber_jij
sza034,yes,yes,no,no,no,no
sza033,no,yes,yes,yes,yes,yes
sza032,no,no,yes,no,no,no
By using the Aggregator, AttributeSplitter, ListDuplicateRemover and ListSorter, I managed to get for each name a list with its unique values. But how can I write this matrix now?
Thanks in advance.
Vera
  • May 22, 2018
Hi @vki, this workflow might help you.
jdh
Forum|alt.badge.img+28
  • May 22, 2018
If your potential values are static (don't change) then use takashi's workflow. If they are dynamic, or there are too many to manually expose, here's an alternative.
keyvalueyesno.fmwt
vki
  • May 23, 2018
Thanks for your answers. takashi's one was perfect for me.
vki
  • January 29, 2021
keyvalueyesno.fmwt
@jdh​
I have to come back to this post, for now I need a solution for dynamic values...
Unfortunately, I can't download keyvalueyesno.fmwt anymore.
Could you explain me, how you managed to create a dynamic matrix?
Thanks, Vera
jdh
  • January 29, 2021
vki wrote:
@jdh​
Thanks, Vera
It turns out I still had the workspace. The MergedSchemaSetter has since been replaced with the SchemaSetter on the hub.
