Adjust vertex order in triangle
  • Jan 14, 2021 2:51 PM UTC
  • 5 replies
  • 95 views
whkarto
Forum|alt.badge.img+14
Hi guys,
I'm looking for a way to adjust vertex order in triangles. First point should be the one with smallest angle between two edges. Remaining vertixes are to be oriented counter clockwise. Is there a build in transformer that offers such functionality or does anyone have a ready to use solution/idea?
Thanks in advance!
Best answer by ebygomm
  1. Extract coordinates
  2. Work out each angle
  3. Rebuild geometry starting at coordinate at smallest angle
  4. Check orientation
  5. Reverse orientation if not counter clockwise already
CaptureCapture
  • Jan 14, 2021 3:47 PM UTC
Hi! Now this seems like a fun challenge. If it's an equilateral triangle, what do we expect to happen then? Or if two angles are the same?
I'll sketch something up for the default case and see what we can make of it. Do you have some sample data, or can any ol' triangle work for my trials?
Forum|alt.badge.img+54
  • Jan 14, 2021 4:19 PM UTC
CaptureCapture
whkarto
  • Jan 15, 2021 9:02 AM UTC
CaptureCapture
Hi @ebygomm​ ,
that looks very promising! I'm currently fiddling with the GeometryReplacer. Which Geometry Encoding Option are you using to pass your triangle attribute over?
  • Jan 15, 2021 9:17 AM UTC
Hi @ebygomm​ ,
I create an attribute which is a string of well known text (WKT)
e.g. POLYGON ((10 5,0 0,10 0,10 5))
and then use this as the geometry source with encoding of OGC Well Known Text
whkarto
  • Jan 15, 2021 9:23 AM UTC
Hi @ebygomm​ ,
Managed to figure out, you've been using OGC Well Known Text. I've had a typo (missing bracket) in my POLYGON string.
