Adding previous month name to output filename (python)
  • Oct 3, 2017 2:14 PM UTC
  • 7 replies
  • 573 views
cstodd
Forum|alt.badge.img+3
I am looking for a way to add the previous months name to the filename of an output Excel e.g. Filename_August.xlsx.
I have been trying to do this with Python (I am a Python beginner) as a Private Parameter using the following:
from datetime import date, timedelta
first_day_of_this_month = date.today().replace(day=1)
last_day_prev_month = first_day_of_this_month –timedelta(days=1)
prev_month_name = last_day_prev_month.strftime(“%B”)
print prev_month_name
This works in python but it fails in FME.
Any ideas?
Best answer by lenaatsafe
Hi @clairestoddart
you could also wrap @david_r solution into a single expression (to be used in e.g. AttributeCreator or as Destination Microsoft Excel File Excel Writer parameter). The expression would be:
@Value(_filename)_@DateTimeFormat(@DateTimeAdd(@DateTimeNow(),-P1M),%B)
erik_jan
Forum|alt.badge.img+26
  • Oct 3, 2017 2:20 PM UTC
If you could do this using transformers, it would be like this:
TimeStamper (date format ^m) to get the current month.
AttributeValueMapper to map current month to previous month (eg: 01 > December, 02 > January etc).
Then use that attribute to do a Fanout (use the Text Editor on the output filename to add the attribute).
  • Oct 3, 2017 2:21 PM UTC
You were close to the solution, you just need to return the prev_month_date value.
Here's working code in a published parameter.
last_day_prev_month = first_day_of_this_month - timedelta(days=1)
prev_month_name = last_day_prev_month.strftime('%B')
return prev_month_name
  • Oct 3, 2017 2:32 PM UTC
If you want to use Python, I like @larry's solution.
Here's one using transformers (you need FME 2017 or newer for this to work, if not go for the solution outlined by @erik_jan), you can then use _result_datetime as part of the fanout.
Result:
`_result_datetime' has value `September'
  • Oct 3, 2017 4:26 PM UTC
Hi @clairestoddart
  • Oct 3, 2017 4:27 PM UTC
Hi @clairestoddart
Nice!
cstodd
  • Oct 4, 2017 11:38 AM UTC
@larry Thanks!  Tested this and it works!  Was indeed so close...
cstodd
  • Oct 4, 2017 11:44 AM UTC
Thanks all for the answers! Much appreciated :)
