Add attribute value as prefix
  • Nov 14, 2016 1:07 PM UTC
  • 6 replies
  • 274 views
I am trying add attribute value as prefix to joined attributes, but I have not succeeded. @bo had quite similar problem Add parameter as prefix...
I have created attributes at main.
Then I expose those attributes at custom transformer
But I cant get prefix when I add Joiner
Goal is to have 1_REGISTRATIONDATE, 1_FORMERPARCELLOCUNITID and 2_REGISTRATIONDATE, 2_FORMERPARCELLOCUNITID on the second round and so on.
Best answer by redgeographics
I'm assuming you want to use a custom transformer to loop through the join several times and add a prefix to the resulting attributes based on the loop counter, correct?
If you don't use a prefix in your Joiner but instead use a BulkAttributeRenamer inside your custom transformer it should work.
Forum|alt.badge.img+63
  • Nov 14, 2016 2:19 PM UTC
Correct.
I have tried that, but it didnt work. I also lost values.
I dont know which of there is correct way, but neither works.
I got it to work with an attribute. Here's my sample, maybe it's useful.
attr-prefix.fmwt
  • Nov 15, 2016 6:58 AM UTC
Thank you, but that does not help. Here is result what I get with your workspace
The table view won't accurately reflect this because it's a fixed schema, in your case not all attributes exist on all features. Does the main Feature Information panel show the correct values?
  • Nov 15, 2016 12:30 PM UTC
Ok. Yes, correct values are at Feature information panel. Thank you!
