Add a prefix to field values
  • Sep 19, 2016 12:20 PM UTC
  • 681 views
Add a prefix that is a constant to all values of a certain field (attribute). For example: Name, Age are 2 values of a field then they are to be replaced by Old_Name, Old_Age
Best answer by takashi
Hi @raghunaren, if the "Name" and "Age" are attribute names, try using the BulkAttributeRenamer (Action: Add String Prefix). If those are attribute values, you can concatenate the constant "Old_" and each value with the StringConcatenator (or AttributeCreator or AttributeManager).
  • Sep 19, 2016 12:36 PM UTC
  • Sep 20, 2016 12:01 PM UTC
Thank you. I was able to get this done with StringConcatenator.
