Access Sharepoint and conditional access policies
  • January 29, 2025
  • 133 views
b.hollebeek
Participant
I am trying to create a webservice to access Sharepoint. FME has been registered in Azure but when I try to set up the connection the conditional access policy blocks my connection.
It looks like it has something to do with the way the http user client provides info to Azure. With the FME default http user agent you just get a blocking error, with the system default http user agent you get this:
It looks like the http User agent does not provide the device ID (apparaat-id): Not available (niet beschikbaar). The conditional access policy demands a registrered device so it blocks this connection.
I can make a Azure connection directly from Chrome or Edge in other apps. what is the way to a solution for this problem?
crystalatsafe
Forum|alt.badge.img+19
Hi ​@b.hollebeek
I'm sorry that no one has responded to your question yet!
We are aware of this limitation, and we have filed an internal service issue (internal reference IDEA-1485) to explore how we can better accommodate this specific Conditional Access Policy.
matthew_banyard
Forum|alt.badge.img+4
crystalatsafe wrote:
Hi ​@b.hollebeek
Just seeing if there was any update on this - as a bit of googling suggests I may be in the same boat here
AliAtSafe
Forum|alt.badge.img+23
  • May 23, 2025
Hello, ​@matthew_banyard!
As of now, we are currently taking a look at it. Thank you for your continued patience and cooperation.
