2016.0 Workbench Help
  • January 20, 2016
  • 8 replies
  • 53 views
adrian_farrell
Hi, has the dockable help window been removed from 2016.0? Cant seem to find it in the same place as 2015 and previous versions - this was a really handy feature
Best answer by takashi
The Help has become an independent application from Workbench. Press F1 key, click "Help" button in a dialog, or select a menu command (Help > FME Workbench etc.), then the new Help will be launched. You can scroll the help document while editing transformer parameters etc.
  • January 20, 2016
fmelizard
Forum|alt.badge.img+21
  • January 22, 2016
You can also "pin" the help app to be on the top no matter what. While it is a surprize that it is gone (and I don't know how we could have softened that), it is nice to be able to scroll it up and down when in any modal dialogs, which was the main disadvantage of the old help window.
arnold_bijlsma
Forum|alt.badge.img+15
The main advantage of the old Workbench Help was that it 'followed' the Transformer you selected in the Tranformer Gallery or on the Workbench. One of the key hurdles (if that's the right word) in FME - in particular for new users - is to work out which transformer to use for the task at hand. I'd normally search the transformer gallery, and then have a quick read through the Workbench Help window which of the found candidates is closest to my needs. Now, I need to go to a separate window, and find each of the candidates again.
mark2atsafe
Forum|alt.badge.img+59
  • January 26, 2016
It should still 'follow' the transformer. If you click on a transformer it will appear in the help as before, it's just that it's now in a separate window.
arnold_bijlsma
Mark, you're right. I should have checked that better :-[
  • May 12, 2016
It's a bit annoying that the Help window isn't attached to the FME window so when you minimize the FME window it minimizes the help windows as well. Why change it in the first place and make it not able to be docked like every other version?
gio
  • May 13, 2016
agree ...should've left it as it was.
jdh
Forum|alt.badge.img+40
  • May 13, 2016
That was the case is 2016.0, but is no longer the case in 2016.1. Changing the focus on transformers in the workspace canvas does not change the help, although it still updates if you click on the transformer in the gallery.
