I've recently built a workbench file/workspace to facilitate a conversion of data. It works on the files I've been given.
I'm using the 2013 version, and have included some Chopper transformers in the work flow. The client - it now appears - is still running a 2011 version, and running it on WinXP too.
The client's FME Workbench issues an error about "Chopper" being for a newer version when opening the workbench file, and fails to produce any output data.
What are our and the client's options to remedy this unfortunate situation ? The client cannot upgrade unfortunately, as his department is currently under decommisioning.
