Unable to reach http:// locallhost/fmeserver
  • March 12, 2019
  • 35 views
After installing FME Server 2018.1.2 ( Build 18590 - win 64 ), I'm getting the following erro message wehn trying toreach the Webgui from the server ( http://localhost/fmeserver ). Where can I found a log to solve that issue ?
Forum|alt.badge.img+62
Here's the Troubleshooting Guides for FME Server (which also cover log file locations).
Most obvious things to check is whether or not all the required services are running properly.
paalped
Forum|alt.badge.img+5
  • April 9, 2019
