Unable to install sqlalchemy python library
  • Sep 11, 2023 10:40 AM UTC
  • 1293 views
Hi all,
Does anyone know how to fix his is error when execute ./fme python -m pip install sqlalchemy --target /Library/FME/2022.2/plugins :
INFORM: Using Python interpreter from `/Library/FME/2022.2/fmepython310/lib/libpython3.10.dylib' with PYTHONHOME `/Library/FME/2022.2/fmepython310'
INFORM: Python version 3.10 loaded successfully
Collecting sqlalchemy
 Using cached SQLAlchemy-2.0.20-cp310-cp310-macosx_10_9_x86_64.whl (2.0 MB)
Collecting greenlet!=0.4.17
 Using cached greenlet-2.0.2.tar.gz (164 kB)
 Preparing metadata (setup.py) ... done
Collecting typing-extensions>=4.2.0
 Using cached typing_extensions-4.7.1-py3-none-any.whl (33 kB)
Building wheels for collected packages: greenlet
 Building wheel for greenlet (setup.py) ... error
 error: subprocess-exited-with-error
 × python setup.py bdist_wheel did not run successfully.
 │ exit code: 1
 ╰─> [98 lines of output]
   running bdist_wheel
   running build
   running build_py
   creating build
   gcc -Wno-unused-result -Wsign-compare -Wunreachable-code -DNDEBUG -g -fwrapv -O3 -Wall -I/Users/kmcdougall/safe/tamoon-worktree/3rd/redistributable/free_use/python/cpython-3.10.6/../PLATFORM-macosx/python3.10/include/python3.10 -c src/greenlet/greenlet.cpp -o build/temp.macosx-10.15-x86_64-cpython-310/src/greenlet/greenlet.o --std=gnu++11
   src/greenlet/greenlet.cpp:16:10: fatal error: 'Python.h' file not found
   #include <Python.h>
   1 error generated.
   error: command '/usr/bin/gcc' failed with exit code 1
   [end of output]
 note: This error originates from a subprocess, and is likely not a problem with pip.
 ERROR: Failed building wheel for greenlet
 Running setup.py clean for greenlet
Failed to build greenlet
Installing collected packages: typing-extensions, greenlet, sqlalchemy
 Running setup.py install for greenlet ... error
 × Running setup.py install for greenlet did not run successfully.
 │ exit code: 1
 ╰─> [100 lines of output]
   running install
   /Library/FME/2022.2/python/setuptools/command/install.py:34: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
    warnings.warn(
   running build
   running build_py
   creating build
   #include <Python.h>
   1 error generated.
   [end of output]
error: legacy-install-failure
× Encountered error while trying to install package.
╰─> greenlet
note: This is an issue with the package mentioned above, not pip.
hint: See above for output from the failure.
[notice] A new release of pip available: 22.3.1 -> 23.2.1
[notice] To update, run: /Library/FME/2022.2/fmepython310/bin/python3 -m pip install --upgrade pip
Error in running the Python command 'python %0'
Program Terminating
vlroyrenn
Forum|alt.badge.img+14
  • Sep 14, 2023 3:06 PM UTC
The specific combination of Greenlet version resolved (v2.0.2), OS platform (macosx_10_*_x86, wheels are apparently release-specific on Mac) and Python version (CPython 3.10) has not been published as a pre-compiled "wheel package", so pip is trying to compile it, but the Python installation that FME ships with is not configured for compilation. You could always install it in a separate Python 3.10 environment and copy it over to the FME Python plugins location manually.
EDIT: You can also run pip install --prefer-binary sqlalchemy, which causes pip to "Prefer older binary packages over newer source packages." when doing dependency resolution.
