The first request is slow- fmeserver uses 5 seconds to find the reader
  • Apr 8, 2018 5:28 PM UTC
  • 40 views
bjarne
Forum|alt.badge.img+5
Fmeserver uses longer time for the first request. If a workspace is run several times it takes less than a second, but the first request is slow. It can take more than 5 secods to creating the reader:
2018-4-8 16:07:39 | MULTI_READER(MULTI_READER): Adding MSSQL_SPATIAL Reader with keyword MSSQL_SPATIAL_12018-4-8 16:07:39 | Using Multi Reader with keyword `MULTI_READER' to read multiple datasets2018-4-8 16:07:44 | Creating reader for format: Microsoft SQL Server Spatial
Hi @bjarne
The FME Server engine likely will load things the first time round, then caches it so the second, third time etc it's a lot faster.
Each FME Server engine restarts after 100 successful transactions or 3 failed ones by default, so you may see this happen from time to time depending on where the engine is in that cycle.
