setting a reference to a folder using shared references.
  • Jul 12, 2017 6:17 AM UTC
  • 139 views
mygis
Forum|alt.badge.img+14
Hello,
I am using FME Server 2016.1 and I need to reference a folder named "farms:. I have added that into the config file and it appears in my resources list, no problem. However, the issue I am having is that I cannot run any workspace when I select the file for processing. If the files are put in other resources like data/myfiles, there is no issue. Below is the configuration I have added into the fmeserverconfig.txt file:
SHAREDRESOURCE_TYPE_7=FILE
SHAREDRESOURCE_NAME_7=rivers
SHAREDRESOURCE_DISPLAYNAME_7=rivers
SHAREDRESOURCE_DESCRIPTION_7=This shared resource is for the rivers
SHAREDRESOURCE_ISMIGRATABLE_7=false
SHAREDRESOURCE_DIR_7=C:/ProgramData/Safe Software/FME Server///resources/data/water/rivers/
SHAREDRESOURCE_SECURITY_DEFAULT_ROLES_7=fmeadmin
The error I get on FME Server is:
statusMessage
Undefined macro `rivers' dereferenced in file `rivers\\shape2shape\\rivers2tab.fmw'
Note, when using the workspace in WB, it works perfectly. If I access to my data from the data folder in the resources, it works as well.
Any help would be much appreciated.
Thanks.
Best answer by stalknecht
  1. If the FME Engines require direct access to the shared resource (for example, a workspace run by the Job Submitter service, rather than using the Data Upload Service to supply the resource), you must also add an entry for the shared resource definition to fmeEngineConfig.txt (also located in <FMEServerDir>Server\\), on the machine that hosts the FME Server Core, as well as any other machines on which engines are installed:
MACRO_DEF <Name> "<Directory>"
Example:
MACRO_DEF SERVER_TEMP "C:/Server"
Example (specifying a UNC path):
MACRO_DEF FME_SHAREDRESOURCE_UNCDATA "//servername/Data/"
stalknecht
Forum|alt.badge.img+22
  • Jul 12, 2017 7:24 AM UTC
Example:
mygis
  • Jul 12, 2017 8:59 AM UTC
Example:
Hi and thanks @stalknecht
I will try it now, but just another question, does the MACRO_DEF have to be a unique name?
Would this make sense?
fmeServerConfig.txt
SHAREDRESOURCE_NAME_7=FME_SHAREDRESOURCE_SCE
fmeEngineConfig.txt
MACRO_DEF FME_DATA_REPOSITORY "!FME_SERVER_ROOT!/resources/system/temp/upload/" \\
MACRO_DEF FME_SHAREDRESOURCE_LOG "C:/ProgramData/Safe Software/FME Server///resources/logs/" \\
MACRO_DEF FME_SHAREDRESOURCE_DATA "C:/ProgramData/Safe Software/FME Server///resources/data/" \\
MACRO_DEF FME_SHAREDRESOURCE_TEMP "C:/ProgramData/Safe Software/FME Server///resources/temp/" \\
MACRO_DEF FME_SHAREDRESOURCE_SYSTEM "C:/ProgramData/Safe Software/FME Server///resources/system/" \\
MACRO_DEF FME_SHAREDRESOURCE_BACKUP "C:/ProgramData/Safe Software/FME Server///resources/backups/" \\
MACRO_DEF FME_SHAREDRESOURCE_SCE "C:/ProgramData/Safe Software/FME Server///resources/data/water/rivers/"
Thanks.
stalknecht
  • Jul 12, 2017 9:31 AM UTC
fmeServerConfig.txt
fmeEngineConfig.txt
Thanks.
The name should be unique but they can point to existing locations that are used in other names.
