Running into this error when trying to restore 2022 backup file. https://community.safe.com/s/article/FME-Server-Restore-Unable-to-Import-Subscribers
  • November 14, 2023
  • 7 replies
  • 67 views
jonathanklarup
I'm getting this known error -
FME Server Restore: Unable to Import Subscribers (safe.com)
When I try to restore my backup file.
Backup file is to large to upload ??
Hope you guys can help, thanks in advance.
Best answer by virtualcitymatt
Update - same error when installing 2022.0.1.1 again.
Looks like you need to contact Safe support to have them fix your fsconfig file?
hkingsbury
Forum|alt.badge.img+67
  • November 14, 2023
Copy the backup file to the resources folder. This will need to be done through Windows Explorer, not the GUI.
Then when you chose to restore the backup, select it from the resource location you copied it to
jonathanklarup
  • November 15, 2023
unfortunately that didn't help.
Still getting same error :
  • Unable to import subscribers because the protocol "gcm" is missing. Please ensure that the post-configuration scripts were correctly run after server installation (see FME Server Administrators Guide for more details).
jonathanklarup
  • November 15, 2023
I'm trying to restore a 2022.0.1.1 to newest stable flow version - is there something I should have done differently, besides following the guide on how to upgrade server ?
Upgrading In Place, On the Same Machine (safe.com)
jonathanklarup
  • November 15, 2023
virtualcitymatt
Forum|alt.badge.img+47
  • November 15, 2023
jonathanklarup
  • November 15, 2023
Yes, thank you :)
I'm on it .
jorgensydfeldt
Forum|alt.badge.img+3
When I restored a server from a fsconfig I had to make sure I had 23 GB of free disk on C:\ for it to pass. Most likelly du to some temp-files but its still a bit irritating. Luckily we run virtual servers so it was easy to extend the disk.
