Hi, I have the next question with FME Server:
The configuration is being done to give access through the url of the aqueduct to the FME server application, which uses the IBM WebSEAL solution as a reverse proxy, I have not found documentation for the configuration of the reverse proxy in the version that we have installed FME server, so I request your kind cooperation to define what would be the steps for the configuration of the reverse proxy.
I’m attentive to your important answer and help.
Best Regards
