Publishing 32-bit workspace to a 64-bit FME server
  • Nov 23, 2015 3:17 PM UTC
  • 46 views
Can you publish a 32-bit workspace to a 64-bit FME server
Best answer by david_r
Hi
Sure, no problem, as long as you watch out for the two following potential pitfalls:
  1. Verify that 64-bit FME can read/write all the formats you intend to use in your workspaces, check here for details.
  2. As always, make sure that your version of FME Desktop isn't more recent than the FME Server you're publishing to (including minor version numbers)
David
  • Nov 23, 2015 3:31 PM UTC
Hi
David
