No FME Server Database after 2022.2 in place upgrade on Ubuntu 20.04.5 with existing PostGreSQL 15.2 installation.
  • Feb 14, 2023 7:47 PM UTC
  • 95 views
Forum|alt.badge.img+4
SetupPostGreSQL.log has the following error returned for each command:
...Permission denied for schema Public.
This is the same setup which has been in use for Server 2021
Thank you in advance!
Brek
merlinegeorge
Hello,
This is a known issue that has been planned for a later release. To confirm, this error is faced when following the install instruction to run postgresql_createDB.sql script ?
As a workaround, would you be able to make this change to the said script and run it -
Remove
GRANT ALL PRIVILEGES ON DATABASE fmeserver TO fmeserver;
Add
ALTER DATABASE fmeserver OWNER TO fmeserver;
  • Feb 16, 2023 12:10 AM UTC
Hello,
Remove
Add
Hi Merlin thank you for the assistance!
I can update the file as suggested but not sure how to call it outside the installation environment.
I've attached a document with the steps taken during the installation and the resulting logs
