Move spatial data (both topology and attributes) from Smallworld to Azure postgre.postgis
  • Jan 21, 2020 5:23 PM UTC
  • 60 views
I am really new to FME. I need to move spatial data (both topology and attributes) from Smallworld to Azure postgre.postgis. Additionally, I also need to take care of the "delta" data moves (incremental updates). Pls let me know your inputs.
1. Is an intermediate XML unavoidable?
2. Is it a plain lift & shift or should I be concerned with Data Modelling?
erik_jan
Forum|alt.badge.img+26
  • Jan 21, 2020 5:31 PM UTC
First choice to make is:
Using the FME Smallworld Edition or
Using the Spatial Biz plugin for Smallworld and the FME Database edition.
Information about the Spatialbiz plugin can be found here:
https://www.spatialbiz.com/solutions/extensions-plug-ins/spatialbiz-plug-in/
The plugin allows for initial and synchronization reads from Smallworld.
