Migrate FME server database to Oracle
  • Jul 25, 2017 5:00 PM UTC
  • 7 replies
  • 102 views
aguan
Forum|alt.badge.img+11
We are using FME server 2017.0.
I am following this article https://s3.amazonaws.com/gitbook/Server-Admin-2017/ServerAdmin4Scalability/4.03.ChangingDatabaseProviderForFMEServerDatabase.html, chapeter 4 exercise 2 to change the FME database provider – from the default to, – not to a PostgreSQL, but to an Oracle12c database. I ran the Oracle scripts to create a FMESERVER user and installed the FME objects. After I changed the fmeCommonConfig.txt (see below) and restarted the FME server, I can not login the web UI using my previous logins. I can login admin/admin, but the contents are pretty much blank. I have no option to import the previously exported fsconfig file. I have to restore the original fmeCommonConfig.txt to go back the working FME server. Feel like I missed something here.
fmeCommonConfig.txt:
# Database Connection
DB_TYPE=oracle
DB_DRIVER=oracle.jdbc.driver.OracleDriver
DB_JDBC_URL=jdbc:oracle:thin:@phoupgisdol03:1521:PGIS3
DB_USERNAME=fmeserver
DB_PASSWORD=mypassword
DB_CONNECT_EXPIRY=60
DB_SQLSTMTS_PATH=C:/Program Files/FMEServer/Server/database
Best answer by laurawatsafe
Hi @ag The instructions for running the Post Configuration scripts can be found here (under step 3):
https://docs.safe.com/fme/html/FME_Server_Documentation/Content/AdminGuide/Post-Config-Scripts.htm
From the description of what you are seeing on your FME Server, I believe running the runPostInstall.bat file mentioned in those instructions as an administrator on your system should fix the problem. Let us know if it doesn't seem to help!
Hi @ag,
May I ask to confirm have run the post configuration scripts before trying to restart FME Server?
aguan
  • Jul 25, 2017 8:57 PM UTC
@Annabelle, what are the post configuration scripts for Oracle?
aguan
  • Jul 25, 2017 8:59 PM UTC
erik_jan
Forum|alt.badge.img+26
  • Jul 25, 2017 9:23 PM UTC
The Oracle scripts can be found in the FME Server folder.
At this location:
First you want to create the user, then the DB (tables, packages etc).
aguan
  • Jul 25, 2017 10:51 PM UTC
At this location:
@erik_jan, I did run those scripts, of cause. Are there any post scripts I need to run?
laurawatsafe
Forum|alt.badge.img+14
  • Jul 25, 2017 11:09 PM UTC
aguan
  • Jul 26, 2017 1:25 PM UTC
Hi @Laura, yes, running the runPostInstall.bat will make the menu items on the left Panel of the web UI available, including the "Backup & Restore", then I can upload the the fsconfig file. This will load all the previous configurations into Oracle, with a few exceptions such as job history and default schedules being disabled. I have to reset the password for the default users like admin, author, et al. Other than those, look like everything works fine. It is a successful migration to Oracle. Thanks a lot for your help.
