Maximum Number of Processes in Parallel Processing?
I remember that the number of processes in parallel processing had been determined by "Parallel Processing Level" and the number of CPU cores, in the old days. The attached screenshot is from FME 2017 Help.
parallel-processing-levelHowever, I cannot find the table above anywhere in the documentations for the current version of FME.
The table above can be applied to parallel processing with a custom transformer in the current version?
Best answer by david_r
Hi Takashi, I found a similar table here:
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Workbench/Workbench/custom_transformer_params.htm?Highlight=extreme
Does that help?
  • February 2, 2022
  • February 2, 2022
david_r wrote:
It's exactly what I was looking for, I don't know why I wasn't able to find it out 😞
Thanks!
