Identify which Operating System is being used?
  • December 17, 2015
  • 24 views
Is it possible to test (from within FME) which operating system an FME workspace is running on?
  • December 17, 2015
Python has these properties or method.
See the links. One of them might help you.
mark2atsafe
Forum|alt.badge.img+43
  • December 17, 2015
I thought we had a published parameter for this, but I guess not. If you want to distinguish between Windows and Linux the best I can offer is the FME_MF_DIR parameter - if it starts with "C:\\" then you can be fairly certain it's a Windows platform.
bo
Forum|alt.badge.img+10
  • January 2, 2024
The FME_OS parameter now may be what you need to use -
FME_OS Returns the operating system on which FME is running - Windows, macOS, or Linux.
bobw
Forum|alt.badge.img+5
  • August 2, 2024
Use FME_OS with AttributeCreator
The ks_rootpath attribute can be used in the file path of readers and writers, making the workspace OS independent.  That is, you can run the same workspace on any platform without modifying paths.
e.g.  @Value(ks_rootpath)/Projects/GIS_TaskRequest/@Value(ProjectNam)/summary.txt
