I need to perform FME server (2022) silent installation in EC2 machine, do I need to create response file or there is any script that we can directly execute using cmd.
  • Mar 17, 2023 11:49 AM UTC
  • 5 replies
  • 87 views
bhagyashrisingh
Forum|alt.badge.img+63
bhagyashrisingh
Thanks for your reply, I have checked above document but regarding load balancer and installing database on separate machine that part how to implement, I am not clear.
hkingsbury
Forum|alt.badge.img+73
  • Mar 19, 2023 7:07 PM UTC
You'll have to configure the load balancer separately, if its an AWS load balance you'll more than likely be able to do this programmatically using the api.
Re the database, you'll have to script the following documentation:
https://docs.safe.com/fme/html/FME_Server_Documentation/AdminGuide/Provide_Database_Server-2-Tier.htm
Here is an example of a script i've used previously. Note, only use at as a guide, this is more a framework than anything else
https://github.com/thewabbit/fmeserverinstall
bhagyashrisingh
Thanks for your reply, I will check above links.
itsmatt
Forum|alt.badge.img+48
  • Mar 20, 2023 7:11 AM UTC
This is great Hamish, thanks a tonne for sharing this - excellent starting point
