HTTPS with PFX Connection Refused
  • December 22, 2022
  • 37 views
I am referencing this article: https://docs.safe.com/fme/html/FME_Server_Documentation/AdminGuide/configuring_for_https.htm?Highlight=ssl
I am on Windows trying to implement using a PFX and password. I am on step 6b and running into an issue. I try to go to https://localhost/ and get "ERR_CONNECTION_REFUSED". It doesn't seem to let me see/download the cert at all. Any ideas? I have checked and double-checked the configurations changes including the path to the PFX and the password.err connection refused
cruzh
Forum|alt.badge.img+3
  • August 18, 2023
I have the exact same issue. Are you trying to install it on a machine with ESRI already installed?
